I have a light switch that has 2 prongs on the backside, and both have an orange wire to it. How do I determine which is the Hot side and which is the switched side? Or is one Hot and the other Grou...
It sounds like you've tapped into the light circuit to get power to actuate the relay. You also need to supply power to the relay contact, and wiring to the motor. Do you have those hooked up?
