I have a light switch that has 2 prongs on the backside, and both have an orange wire to it. How do I determine which is the Hot side and which is the switched side? Or is one Hot and the other Grou...
The relay and motor were already hooked up to 12VDC. All that was required for the new relay from Power Gear was for the switch to have 12VDC to the center switch prong. I think I should be able to use my meter to find 12VDC at the relay wiring harness at least.
