Passin_Thru
Aug 12, 2014Explorer
Most converters don't show problems, just go kaput but we had one do the same thing. Just look at the Amperage and style for a replacement. You most likely won't find an exact replacement but it needs to be the same size or a higher amperage by maybe 10 AMPS to replace the old one. It just has to fit in the same place. They are easy to put in, the difficulty being in where it is placed but can be done with a screwdriver. Ours was $65 and took 10 minutes in an Arctic Fox TT. You can pay $250 for a repair facility to do it but all you do is hook Red to Positive, White to ground, copper to the ground wire (usually bare) and plug it in.
38,782 PostsLatest Activity: Sep 10, 2026
