Dakzuki
Nov 07, 2014Explorer II
mda wrote:
I went with Trojan Group 27 AGM in my motor home for similar reasons. I have PD 4645 multistage converter. I have found that the battery charges fairly quickly using the genny. Not sure, I am no battery expert, but I believe AGM's are more efficient. I can tell you, though it was expensive, the battery is a brute when it comes service.
AGMs are more efficient. They have less internal resistance so less energy is used to create heat when charging and (more importantly) discharging. I prefer to use the energy of the batteries to run my RV lights etc rather than heat the underside. That internal resistance is also what factors into charging times.
38,774 PostsLatest Activity: Apr 26, 2026
