horton333
Mar 16, 2017Explorer
Does the generator come on when the air conditioner comes on?
If they go dim after only 15 minutes then batteries are perhaps weak or there is a huge load somewhere, or less likely the battery charging charging system. You would need to measure the voltage when charging to know, should be greater than 13.6 and hopefully over 14 volts when charging.
If there is an invertor (changing 12 volts DC to 120 AC) then turn it off and see how fast things drain down.
38,769 PostsLatest Activity: Apr 04, 2026
