Isaac-1
Apr 22, 2018Explorer II
It should be fine as long as the 15 amp outlet is wired properly and is in good condition. If it is an old outlet with corrosion in it, then it may overheat with the 12-13 amps worth of load that may be found from an RV air conditioner. This of course assumes there are no other loads present.
