My coach is similar to the OP's with a max GVWR of 18,000 Lbs. and the coach builder' recommended pressure is also 80 PSI. For my coach 80 PSI will give the tires a load capacity that is just above the axle capacities. Loaded for a weekend the coach only weights 15,250 LBS. so even at 80 PSI I'm over inflated. Haven't found an inflation table that goes below 80 PSI so that's what I run. Also once on the road I usually gain 10 PSI as reported by the pressure sensors.
Inflate to a pressure you feel comfortable with but don't go below 80.
