Traveler7
Jan 13, 2015Explorer
Big Day Today! We finally got some decent weather with the sun coming out and Temps in the high 30's so it was time to install the backup camera and put my new license plates on!!!!!!
Here is a pic of the camera system I bought from Walmart.com-
Pyle Audio PLCM34WIR which is a wireless camera with night vision and a 3.5 inch color monitor
The camera is a license plate attachable model so time to put my new plates on as well:
I ran the wiring for the camera behind the plate light housing
Of course working on any project leads to fixing other problems, in my case the plate light wasn't working- bulb was damaged, but there was no power to it either...darn....traced the power issue to the bare metal connection Dodge used to make a circuit and be able to open the left back door without wires dragging out :
You can see both sides of the circuit above. To get power there I needed to file and clean the bare metal on both sides and make a shim for the door side of the circuit to push the contacts together more securely
I secured the shim tightly and mounted the camera and attached my new rear plate
Next I pulled the left tail and backup lights- the backup bulb was out as well!
Cleaned it up and inspected the wiring
I had to go to my FLAPS and buy light bulbs and electrical tape, good news on this was I followed a DeLorean!!!!! BACK TO THE FUTURE DOC!!!(sorry , no pic)
I created my ground wire for the camera (Blue wire at right)
and tested the camera by taping to the 'hot' side of the plate light connector
and Voila!!!!
a picture!!! (this is my first twelve volt wiring project so I am frankly amazed when anything works!)
Final part was connecting the camera hot wire to the backup light and I did this by butt connecting it to a larger jumper wire (white)and exposing the backup light hot wire and splicing with black tape to finish it off
Then cleaned up the wires with some twisty ties and put the tools away and done!
Finally mounted the front plate and TAO 7 is ready to roll!
Thanks for staying tune...new tires and shocks as the next upgrade when I can afford it....
and Voila!!!!
a picture!!! (this is my first twelve volt wiring project so I am frankly amazed when anything works!)Final part was connecting the camera hot wire to the backup light and I did this by butt connecting it to a larger jumper wire (white)and exposing the backup light hot wire and splicing with black tape to finish it off
38,780 PostsLatest Activity: Jul 20, 2026
