Traveler7
May 13, 2018Explorer
Wow, been a long time since I updated...
I am getting the van ready for a trip to Prudhoe Bay, AK and touring Alaska in late Aug./ early Sept. so the new posts will deal with what's been done and what's up!
Just finished a big mechanical project by taking the van to a mechanic and having him fix ALL the oil leaks!
This involved dropping the oil pan and reworking the dipstick tube attach point, redoing the rear seal and putting a high temperature valve cover gasket on the hot exhaust side of the manifold. Also had the radiator pulled and refurbished and tested and added an aftermarket temp gauge to replace the bad one on the dash.
The van used to leak quite a bit of oil- now you can park it on a white sheet of paper and nary a drop!
Now I am working on two projects-
1) Adding a Solar Panel to the roof and running the cabling, and
2) redoing the flooring after the failure of the materials I used on the previous job.
I will be routing my cable thru the upper refrigerator access vent so I pulled off the upper and lower vents today to clean and paint them and prep the upper by cutting an opening for the cables.
I covered the openings with a plastic bag for now.
I also ripped the old linoleum flooring out to get to the subfloor and get the flooring I added that had peeled up at the sides and come unstuck out. It really looked bad
I will replace the flooring with a much sturdier and thicker click together floating floor.
So look forward to more posts weekly and thanks for checking in!
38,782 PostsLatest Activity: Sep 02, 2026
