Traveler7
Jun 09, 2018Explorer
Big Day for the van today- cut out the piece of osb board for the upstairs bed and my flooring came in a week early so I picked it up! My brother amd I spent all day installing it.
It is from Lumber Liquidators and is a laminate called American Beech. It was on sale for 59 cents a foot, so a bargain1
Here are some pics:
I cleaned and wiped down the plywood subfloor and covered the hole where the table mount used to be screwed into-
Then we laid down the foam layer for the click together floating floor to float on
Here sre the boxes of flooring- American Beech color
Laying the first couple of clicker boards was very difficult and frustrating because the van is old and the cabinet has bowed in so nothing is square. Once we got several together it became easier, but there was some swearing and bleeding until then!
Detail of the flooring-
finished laying it!
This was a big deal getting this accomplished and Cutting the board for the bed. I also experimented with running the fridge off of the battery and inverter and ran it that way most of day with partly cloudy weather and then storm clouds rolled in and I went back to plugging it into the external power. Fridge was at 29 degrees all day so I need to work this out and try for an even temperature around 35-40 degrees.
I also wired in the Propane detector today and it has power- haven't experimented with it yet.
More notes later on next project and completing the flooring by adding based board and trim.
Thanks for checking in on my project- please leave a comment if you have time :-)
Here are some pics:
finished laying it!
38,782 PostsLatest Activity: Sep 02, 2026
