Traveler7
Jul 02, 2018Explorer
New things to install for the classic 1977 Dodge B:
New Seaflo water pump and a Security system with door alarms and motion sensor alarm!
Pics
New Security System
40 year old pump that finally got too old- still makes noise, but I'd guess the seals are shot- sure it could be rebuilt and probably go another 40!
So I installed the new pump enough to test it and it works great, but sadly I have acrack in the old plastic piping that goes under the van.
When the van was plumbed they drilled out a large hole to pass piping through and then cut the pipe and put an small elbow insert and attached the other end of the pipe that ran to the faucet and sink.
I figure I will need to cut the old section out and get a new connector and new joint to attach everything up so probably this weekend for the fix. In the meanwhile I will study and wire up the Security System!
Thanks for checking in on this project!
Pics
New Security System
38,782 PostsLatest Activity: Sep 02, 2026
