gbopp wrote:
asgarland wrote:
That's good information thanks. So I definitely plan to use that on the roof. I was originally going to caulk and use the gallon cans of flex seal on the roof and paint it on the entire thing. My thought was if its worth doing its worth over doing.
I wouldn't use Flex Seal. I think a forum member tried it. Eventually it dried out and peeled.
If you coat the roof, use something made for a rubber RV roof.
There are several to chose from.
That is, of course, assuming it has a rubber roof.
If it has an aluminum roof, use something intended for sealing an aluminum roof. :)
