donn0128
Sep 26, 2018Explorer II
Probably the m400 chassis.
As for plubming and electrical? You might, maybe find someone who has the info, but not likely. Definitely not worth wasting your time looking. Following lines and wires is pretty simple. If your really into it, a signal generator will allow you to trace the wires from fuse/breaker to fixture. Then a lable maker will get everything marked.
Your biggest concerns right now is leaks. Clean, and seal everything. If you dont know how to do the windows and other openings, ask before you screw things up. Its not hard to do, but unless you use the right products your only going to make things worse. Once its sealed tight outside, you can start on the fun stuff.
Make a list of all the appliances and search the internet for that make and model. Download the manuals, print them out and you will wind up with a pretty extensive manual.
38,763 PostsLatest Activity: Dec 05, 2025
