sputterbug10's avatar
sputterbug10
1984 Ford Honey
I'm looking at buying a 1984 Ford Honey. I don't know much about these. I wonder if you all think it worth the $6000 she wants for it. The listing says, "1984 honey 23 ft motorhome rv. I hate to see it go always been good to me just time for something bigger. Has lots of work done over the years but it was done right not slapped together and painted! Every window or seam is sealed with rv lap sealant the roof was painted with roof sealer so no water leaks.Up frount above the cab was rebuilt from the tin to the paneling with new insulation as the same for the back wall in the bathroom. It has a new refrigerator electric only but all the other appliances work as they should including furnace,and ac will freeze you out. As for the truck all the work was done professionally it has new exhaust manifold gasket, both fuel tanks, water pump,voltage regulator, u joints,rubbor brake hoses frount and rear,steels in good shape,frount and rear wheel bearings serviced with new seals,all brakes have been inspected good with new rear wheel cylinders and hardware,all fluids front to rear changed,tires are only 2 years old." Thank you.
