turbojimmy
Aug 09, 2015Explorer
gbopp wrote:
Can you raise the front to help drain the water?
I would not use cement on the roof.
Find the leak and repair it with Eternabond or Dicor self leveling caulk.
Then recoat the roof.
I agree. Reposition it so the water runs a different way. While leaks are tough to find, it's not rocket science either. There are holes in the roof for stuff to poke through. Seal those holes.
The A/C is a little different in that it will have a seal where it sits on the roof. You can wrench it down tighter from inside if that's where you suspect the water is coming in.
I would guess that in 1985 your roof is aluminum?
38,781 PostsLatest Activity: Aug 12, 2026
