gulfstreamer97's avatar
May 09, 2018
1987 ford E350 460 7.5L backfires
acquired a 87' E350 econoline w/ 460 7.5L EFI cab over motorhome. this thing sat for some time owner told me "the fuel pump needed to be replaced, parts are there" replaced parts given (fuel pump, filter & lines) ran to an external fuel supply. didn't want to clog new filter. purged air from line engine cranks over (sounds good) wants to start but doesn't. spray a little starting fluid in breather and starts to turn over. runs for about 3 r 4 seconds, dies. repeat procedure and same. repeat again and it back fires from throttle body hose. any help would be much appreciated. this motor home is not my main traveler. this is one that was handed to me as a project. but would like to get running for small trips with family. that way i dont have to take out "UNC" short for uncle, my 1997 palm breeze, gulf stream. thanks in advance. also first time to forum so if there is anything i need to put in posts to make this as easy as possible please mention
  • If it sat for a longtime the fuel could have gone bad. I would drain out the old fuel and put fresh stuff in.
  • All gas motors need three things. Air, fuel and, spark. Your missing one of those.
