Andonso
Apr 12, 2018Explorer
After some research one person from the Ford forums stated there may be some difficulties when swapping out springs and tires to larger sizes.
Reply from member of a Ford-Truck forums.
You can’t just put heavier springs under the front end or else it will throw your camber way out of whack. The axles pivot under the center of the van and are engineered to factory specs for the camber depending on the weight of the van and have matching coil springs to achieve the proper camber. A heavier spring will raise the van but will also throw the front wheels into a positive camber. That is what happened on my van when I replaced the coil springs with springs that were supposed to be replacements for my original ones. Due to the positive camber the new tires quickly started feathering and wearing out on the outer edge.
I think perhaps he's correct that installing larger tires would effect differentials with 3.55 gears so perhaps I could go another ~inch larger in tire size without effecting the differentials torque too much?
Raising the springs evenly front and rear may work as long as the drive line angle and wheel camber isn't effected.
When installing a lift one needs to consider the drive line angles of the driveshaft where it connects to the diff and transmission or for a 4x4 the transfer case. If this is off by too much where adjustments won't correct the problem what often is done is a SYE (slip yoke eliminator) is installed. SYE's use a double cardan u-joints which allow for wider drive shaft angles.
Two rear wheel drive vehicle it usually isn't as much of a problem as with 4x4 vehicles with a transfer case between the transmission and rear diff.
I think for now I'll just install a new set of tires and ask the tire shop what they think about going larger than a stock tire size of 235/R16.
One person state that 31x10.50-15 have been installed on E-150's without any rubbing.
I think perhaps I'll ask at a local RV shop that works on RV's should know which tires sizes work and about installing heavier duty springs, etc.
