ggardne2
Apr 30, 2018Explorer
You have an AOD which is a 4 speed version of the Ford FX/MX/FMX based off of the original Borg Warner Cruise-Omatic. It uses a single Ravigneaux gear set and is not related at all to the C4 or C6 family which are Simpson gear set 3 speeds. The AOD was manufactured until 1992 at the Ford Livonia Transmission plant. It was replaced by the AOD-E which evolved into the 4R70W/4R75W transmission.
Any Mercon-V fluid will work well in this transmission.
38,777 PostsLatest Activity: May 24, 2026
