fleetwoodjambo
Jul 17, 2018Explorer
Thanks. I ensured both batteries are good sorry did not mention, they are also new. I do have the emergency start under the dash on driver side. Is there a switch that needs to be switched inside the RV before using DC power? This was my concern as I have never owned one before, but all fuses at the 4 breaker panel under bathroom sink appear good (I pulled each one out and inspected). I found it interesting that when both battery cables are attached to the same solenoid terminal everything works. Am I getting double AMPS this way, or should one 12 volt battery be able to start the generator on its own. Everything did work one time (all lights and generator turned on) when I bought the first solenoid from Napa but only once, almost like something was tripped. I'll check all cables. There is also alot of breakers (little plastic boxes with what appears to be ground wires attached) on the fire wall under the hood, I replaced a few of them but wasnt sure if these play into the coach not having DC power.
