Dog_Trainer
May 26, 2014Explorer
It sounds like the alt is not being excited although if my memory is correct the si10 is self exciting. In the future if you replace the Alt. You can put on a cs130 and get 130 amp output. Just purchase the adapter and make sure you get a 12V wire that is fired by the ign. Switch it will connect to one side. Of the connector the other wire will be one that has 12 V continuously. If you are not outputting from the Alt. Check to make sure you have a wire that is feeding 12V continuously it should likely be the largest wire and it may be red.
38,763 PostsLatest Activity: Jul 22, 2018
