usersmanual
Nov 18, 2016Explorer
Dog Trainer wrote:
It sounds like the alt is not being excited although if my memory is correct the si10 is self exciting. In the future if you replace the Alt. You can put on a cs130 and get 130 amp output. Just purchase the adapter and make sure you get a 12V wire that is fired by the ign. Switch it will connect to one side. Of the connector the other wire will be one that has 12 V continuously. If you are not outputting from the Alt. Check to make sure you have a wire that is feeding 12V continuously it should likely be the largest wire and it may be red.
obviously he has 12V to the alternator and he clearly says
""I checked the post on the back of alternator, it shows the same voltage as the battery""
38,763 PostsLatest Activity: Dec 25, 2025
