kimberlysmoore
Oct 30, 2017Explorer
wildmanbaker wrote:
Is the hum at the breakers and not anywhere else? try cycling the breakers 4 or 5 times with all 120 volt power disconnected. It may be the main breaker, or loose connections in the breaker box, or the transfer switch. If you are not comfortable with 120 volt AC, get some guidance from someone you may know. Things are tight to get to the transfer switch, if you have one.
Hum is at the breaker box.
Buzz was at the dash or front end of the gene (unsure). Haven't heard buzz since yesterday.
If I turn off the microwave at the breaker box, him stops. If I turn on the microwave but turn off the other appliances, hum gets smaller.
Without microwave breaker on, no bedroom power.
To answer someone else's statement: refrigerator is small house refrigerator, no LP.
We want to put in a side by side double door 3-way eventually, but this is all weve got for now.
38,763 PostsLatest Activity: Dec 05, 2025
