The_Waites's avatar
The_Waites
1990 dodge roadtrek
Drove our 1990 to get gas 24 miles round trip. Arrived at our driveway and it wouldn't go into gear (none). Turned off, went back out and it drove fine. Decided to go to carwash and it wouldn't go into gear again. Any ideas as to problem? Automatic transmission was not slipping just stopped no forward & reverse. Thank you.
  • Naio's avatar
    Naio
    Explorer II
    Yeah, you definitely do not want it to quit on the freeway.
  • Get it checked out by mechanics. Go directly to the shop. Do not keep gambling. Do not pass go or collect $200.
  • be more specific
    do you get R, N D ,2,1 ?
    if you put in D and rev..does the motor rev freely like no load or does it strain...in R?
    if the fluid level correct
    are you parked on level ground
    the more detailed you can be- it helps to rule out possible causes
    you can't assume this will fix itself...cause when it fails it won;t fail in front of a tranny shop
    mike
  • Tyler0215 wrote:
    1990 is probably mechanical linkage not electrical. A visit to a transmission shop is in order.
    Just started van and it went into gear, hope it continues to work right.
  • Lwiddis wrote:
    Mary, is this the original 1990 transmission?
    trans replaced about 8 yrs ago
  • 1990 is probably mechanical linkage not electrical. A visit to a transmission shop is in order.
  • linkage seems ok, fluid ok, pink & sweet smelling...no sounds from trans, motor revs.....maybe electrical?
  • is the gear lever working as usual- does it seem to move a linkage...do you hear stuff moving when you move the lever?
    ( I once had my linkage get funky on a long drive across the desert...and found out when i stopped for gas...luckily able to fix with a found bent nail)
    what happens when it doesn;t move- just revving?
    fluid level?
    mike
