tylerdurdeno9
Nov 10, 2014Explorer
1990 Dodge Xplorer Fuel Leak
After returning home after shooting some photos I noticed a very strong fuel smell. After checking under the van there was a large amount of fuel leaking over top of my transmission. After further investigation it appears my metal fuel line must have broken its mount and fell upon the transmission itself and burned through! The fuel line is set up as follows.
-fuel pump to line travels up the drivers side up to the transmission
-the line then passes over the transmission
-lines are then connected to rubber fuel lines on the other side of the transmission
-rubber fuel lines are then connected to metal fuel lines to the engine.
My question is would it be advisable to replace the metal line with a rubber fuel line in braided steel? I feel as though as long as I keep it clear of the transmission there will not be a problem. Has any xplorer owners here replaced the fuel line from the tank before? Thank you for your time.
