BertstertExplorerNov 03, 20201990 fleetwood bounder 34s electrical newbie helpSo I’ve been having problems with my engine which is a Chevy 454 7.4 HEI and it is giving electrical shock on spark plug number two. Also my fuse box has a charging light that will go on and off rando...Show More
rgatijnet1Explorer IIINov 04, 2020Check to make sure that the spark plugs that you are using are the right ones. You may want to switch to a cooler spark plug.
Related ContentFleetwood Bounder reviewsElectricFleetwood Angler wiring2017 Fleetwood BounderFleetwood Bounder Slide
