dougrainer
Nov 04, 2020Nomad
Here's your Fleetwood manual.
https://big.nyc3.cdn.digitaloceanspaces.com/revgroup/documents/bounder-1990.pdf?mtime=20190830093022&focal=none
1. The Spark plug issue will be a CHEVY problem Nothing to do with Fleetwood
2. The fuse block charging light is FLEETWOOD. Has nothing to do with the Chevy Chassis Charging system
3. The Inverter is aftermarket as Bounder's did not come with an Inverter in 1990.
4. The trailer braking system is also aftermarket. Doug
