enblethen
May 26, 2013Nomad
Chassis fuse block on GM chassis is located under dash left side of the steering column.
There is 12 volt fuses located behind metal plate next to 120 volt cicuit breakers.
There is on some Fleetwood products fuses in battery control center under hood driver's side.
What is your problem that you are trying to find? Is it a 120 volt volt issue or a 12 volt issue? 120 volt circuits normally do not have fuses.
You said "heater" ? is this the propane furnace or was it an electric one?
