Yoster's avatar
Yoster
1990 P30 454 Chevy Radiator For a Fleetwood Cambria
Howdy, this is the 7.4L V8 engine by the way, I'm prepping this fine machine for some long summer hauls, it's got low miles but has aged in the elements and I appear to have a rotten radiator core. The parts store didnt get the correct radiator for the chassis, so I returned it, and the only other thing I can find it being is the CU 308 radiator, which would be difficult and expensive to find. So im also thinking olaboit a recore also. The thing is the CU 308 looks different also, the way thebradiator sits under the cab requires the fill spout to come out of the front and not the top. Any info or ideas would be highly appreciated!
  • call up Complete Radiator in Orlando FL, they do shipping, should not be near 2400. It may be a grand as they don't know you. shipping price be the pits/
  • I would go by an O'Reilly auto parts. They are not showing on website.
    Here is one from Delphi.
    Delphi
  • Call Fleetwood and ask them. They are very helpful and will direct you in the right direction.
    They might even be able to order you one up.
  • Can you guys confirm to me what kind of radiator it is, cause the CU 308 is not it.
  • I didn't have any problems getting the correct radiator from O'Reilly auto parts.
    Your chassis should be a p-30.
    I was able to get an aluminum radiator with more cores then factory. Runs much cooler.
  • You have the top and bottom tanks so a radiator shop would be the place to go.
  • YEp, My Fleetwood Southwind appears to have the same radiator. I had to go with a complete new buid of radiator. About $2400.00
    You could try workhorseparts.com
