thead's avatar
thead
1991 Beaver Contessa Converter / Inverter
Where is the Converter located, It's not under the Bed or Sofa I'm lost.
  • Could be under the fridge too. Look for any metal cover with louvered vents and it could be behind that. My '94 Foretravel is in one of the basement compartments, just to give you some ideas. And they all look like a metal shoe box with a bunch of wires going in and out.
  • Check again....... they looked different back then. Mine was at the bottom of the bed (toward the front of the motor home). It looked like a stand alone unit that was just dropped in and was held in place with 2 screws.
    Another possibility.... You don't say if it ever worked. If you bought the MH used, someone may have removed it.
