westtexus's avatar
westtexus
1991 Fleetwood Flair
I am a long time member, haven,t been on in a while. I just bought a 1991 Fleetwood Flair, 25', Ford 460. It's in great shape, a couple of minor problems. The washer spray does not work, and I can't figure out how to remove the washer fluid tank to replace the pump. Another thing is one of the hoses that runs from the air filter box to the smog pump is damaged, causing big leak. I can fix this, but am wondering if it has any effect on fuel mileage.
I ordered a fuel pump/sending unit, this should fix the gas gauge.
If anyone can help with any of this that would be great.
  • well Crasster, fixed it a different way. Blew through with air hose, found obstruction, cleaned nozzles and part of hose with tool used to clean cutting torch tip holes. Now its working well.
  • One "trick" I have found (archaic I know, is to empty all fluid out of the tank, hold the tank hose in the air (prop it up) and fill with oil. The hose must be above the pump. (marvel mystery oil works well). Then tap the pump with the back of a screwdriver. Have a friend try to engage the pump while tapping.
    Often pumps are "stuck" from idle time and detergent oils will free them. I do warn if the pump engages that you WILL get oil on your windshield so be sure to have a degreaser and window cleaner available.
  • The washer pump has power, so need to remove, the hose leak will be an easy fix. Thanks for your reply.
  • On the washer pump, check for voltage at the pump first. If it has been sitting a while it might be just stuck. Any big air leak should be dealt with as I am sure it will have some negative effect. Good luck
