Sloop_Smitten
May 08, 2013Explorer
If your Tioga is like my Jamboree the grounds in the rear running light are via one of the two threaded studs that hold each light in place. I would remove each lamp and clean the stud amd mating surface in the lamp and see if it improves. It might be a good time to replace them all if they are the original lights. They are relatively inexpensive. The grounds are wired in series so a difference in voltage often times is linked to a bad gound connection somewhere. The positive connections are in parralel however.
