I vote for the Delo. It has or had more zinc which cams from the era and other parts need in abundance. It is real slick for sliding surfaces.
You can buy the zinc additive too.
Real Synthetics are really slick, that is the ones made from Esters, and may not need the zinc but I am not a lubricant engineer or chemist.
The clearances in older engines are greater than new ones, I understand, so same grades as were originally recommended.
Who ever sells whatever, remember, they have the right stuff you need, so check it out yourself. Until then I would run Delo. jmo
