joshtb86
Sep 19, 2017Explorer
Krusty wrote:
Sounds like it is operating normally. None of the things you mentioned (fridge, lights, fans) would run off the chassis battery. They would run off the coach battery. None of the 120 volt AC stuff will run off the 12 volt system unless you have them connected to an inverter.
okay so follow up ?s
1. if i connect the 12v dc batteries to an inverter, and connect that to the AC system, i would be able to run the AC stuff off the dc batteries?
2. sorry if this wasnt clear - i cannot run any of the dc stuff (lights in the back, etc) off either battery - they simply do not work unless the alternator is running. does that mean the batteries are dead?
