- jyrostngExplorerWith zero info, the fuel pump.
- Tyler0215ExplorerClean the battery terminals, while the cables are off ,charge the battery. Clean the ground. Still won't start, check the fuel, while the air cleaner is off, replace it.
Still won't start, call the tow truck.
90% of the time it's one of the three. - gboppExplorerYes, be more specific please. If it will not turn over make sure the battery terminals are clean/tight and the battery is charged.
If I have a (very) little corrosion on the terminals, my 96 Fleetwood Southwind wind not turn over. - Matt_ColieExplorer IIRobert,
Please be more specific.
If it cranks and does not fire and it is a throttle body 454, then get a timing light and hook it up to an plug wire.
With air filter open, crank with the timing light on.
If it flashes, you have spark.
If it does then you should be able to see the fuel stream in the flash.
If there is no fuel stream visible, get someone to put an ear on the fuel fill while you turn the ignition on.
Can he hear the fuel pump run? Yes/No
That is the first 100$ of diagnostic.....
Matt - RobertCoreyExplorerChevrolet
- ChrisatthebeachExplorerWhich chassis?
38,783 PostsLatest Activity: Sep 23, 2026
