Grandpere
Mar 14, 2015Explorer
The Bronco is a great vehicle to tow because it has a manual transfer case. Just put the transfer case into neutral, leave the tranny in park, turn the key so you steering wheel is unlocked, and you are good to go. You will need a tow plate, a tow bar, an auxiliary braking system, and lighting for brake, tail and turn signals. Some people use integrated lighting, but we prefer to use external lighting. Just stick the lights on the back end and plug them in. I am leaning towards the Blue Ox braking system as it is wireless. Also you will need a class III hitch as a minimum, we are going to be upgrading our class III to a class IV.
If we were not planning on buying a new 2016 F150 Supercrew I would be seriously pursuing purchasing a Bronco to pull behind our MH. But then I am a die hard Ford person.
Good luch and safe travels.
38,776 PostsLatest Activity: May 14, 2026
