Argosy24 wrote:
Electric fan I'm guessing because you're talking about adding a light.
If it is you need to find out if it's for engine cooling or moving air over the AC condenser in which case it will run with the AC switched on.
Ok Its the electric fan in front of the AC condenser/oil cooler. and yes I just got the ac in front charged . So It always runs if the air conditioners on OK , I will have to check it out. This is first time I have run it when the front air conditioners working. Could I also try to turn on the front heater and see if blows hot air . that would tell me if the thermostats stuck open . Or maybe its the gauge acting up. thanks for the help.
