jyrostng
Aug 29, 2015Explorer
https://www.cumminsonan.com/www/html/Common/pdf/rv/F-1123.pdf
Starting And Stopping Procedures
Your Cummins Onan generator can be started and stopped from the integral
control panel on the generator, or from the optional remote control panel inside the
vehicle if your RV is so equipped. Your Operator’s Manual outlines the simple steps
for starting and stopping. Remember to:
• Before starting the generator, turn off air conditioners and large electrical loads.
• Before starting in cold weather, turn off all appliances for best long-term
performance.
• Prime by holding stop (all Quiet Diesels, Quiet Gas 3600-7000).
• To start - press and hold start at the control panel or at the set.
- Quiet Diesel: auto pre-heat flash, then crank/start
- Don’t over-crank with no start
• Before turning on appliances, let the generator warm up for a few minutes.
• Turn off air conditioners and large electrical loads and allow the generator to run
for 3-5 minutes before stopping, to allow the generator to cool down.
performance.
38,769 PostsLatest Activity: Apr 03, 2026
