1993Coachman
Jul 21, 2014Explorer
1993 Coachman. No hazard, turn, or brake lights working
Good Morning All;
Have a 93 coachman catalina sport on a Ford Econoline 350 chassie. I have no hazard lights, turn signals or brake lights. What I've tried:
- Checked all fuses in fuse panel under steering wheel & fuses on the panel located under the bed in bedroon. All good.
- Replaced multi function switch
- Bought a hazard fuse (round canister), however the fuse panel under the steering wheel does not have wiring/clips to attach the canister to, although clearly the fuse panel was designed to accept the canister (possibly std fues panel for other econolines)?
- All other lights work. Headlights & side markers.
Unrelated. Whats the purpose of the battery under the floor (battery box mounted to the frame) located under the staris where you enter the RV?
Thanks, much appreciated
