Psam's avatar
Psam
1993 Safari continental 37' cracked frame, bad shock install
What a nightmare.
Did some front end work recently, noticed that both sides of my frame are cracked at the shock mounts connecting to the frame.
Who in their right mind uses a bolt without a washer or a back plate?!
Especially on a load bearing component.
Pioneer metal works in Washington state did this.
This is what they had to say:
"We put our product on in the original shock bracket position where the manufacturer had put the original shock bracket. We did not drill any additional holes that might weaken the frame. What we added did not add any additional stress to the frame. - Pioneer metal works
Clearly, they have relocated the shocks.
Thanks for reading, ill keep you updated.
Pictures:
http://www.irv2.com/forums/f258/1993-safari-continental-37-cracked-frame-from-a-botched-koni-shock-installation-471798.html
  • The pictures are not the same. Crack does not show thru and you have a brake line going thru one and not the other.
  • They were installed in 2010.
    Yes, I bet the cracks appeared over the first pot hole after the installation.
    Bad engineering.
  • The pictures look like they have been in that position fo a very long time. And the shocks, hardware don't look new! The cracks in the frame have been like that for a while judging by the rust that is showing.
