psalm10720 wrote:
One of the ways I was thinking was to drill a hole through the top of the power cable box and attach a female connector so that I could use a male to male cable to attach to the park feed.
As far as the right side connector near the outside stereo I would assume that TV Signal would feed the system from that receptacle allowing signal to go to the powered face plate above the drier/co-driver.
I think that connection is for an outside TV. Guess you could back feed through it but I don't believe that was the intent. As mentioned, look at top of wet bay or utility hookup bay. That's where ours was on our 1994 Bounder.
