j-d
Jan 22, 2017Explorer II
Charger and Converter should be together. In our 2002 coach, they're also combined with breaker and fuse panels. Not all are! Our 1984 coach had
Converter/Charger (and the Charger part burned out its breaker)
A 12 VDC Fuse Box (both in a cabinet under the fridge but not together)
A 120 VAC Generator Breaker Panel
A 120 VAC Shore Tie Breaker Panel (both in a cabinet under the stove, across from the fridge)
Can you post Make/Model of what you've found so far?
And/Or Pictures of them?
38,782 PostsLatest Activity: Sep 10, 2026
