- Are you sure of heighth at 10'4"? I would say more like 12;4".
- RLS7201Explorer III suspect 10'4" is very close. My 95 Bounder is 10'4" tall at the top of the air conditioners.
Makes little difference weather Chevy P32 with 225/70R19.5 tires at 31.9" diameter or Ford F53 235/85R16 tires at 32" diameter.
Fleetwood gas coaches of that era all used the same body.
Richard - LouLawrenceExplorer III would be almost 100% sure it will be taller than 11' 3".
- cayugaExplorerThanks! I guess I'll have to go check it out and measure.
- My 1993 Fleetwood Pace Arrow on Chev P-30 chassis clearance is 11' 9" with 19.5 tires. Some Ford chassis have 16 inch tireswhich will effect heighth.
I would not truast anything in writing as for heighth. Take a straight board and measure to ground.
I would not use my numbers for your rig either! - CA_TravelerExplorer IIIAnd don't assume a 27 year old RV is stock.
- NEVER TRUST A SPEC OR LISTING. The ONLY way to be sure, is for YOU to measure the height. Very few Gasoline Fleetwood would be over 12 foot 6 inches. If any. Doug
38,782 PostsLatest Activity: Sep 10, 2026
