Mike_Hohnstein
May 11, 2013Explorer II
P-30 is a pretty good base for a class A, lot's of aftermarket support with solutions for most short comings of the original design. One thing that comes to mind is the heater shut off valve. It's cable operated on most chassis, usually doesn't shut off the hot water flow to the dash heater core, Napa has a replacement that is a positive shut off valve. One of these will cure weak dash air performance. IPD anti-roll bars front and rear are usually a huge improvement to cornering performance.
