ericsmith32's avatar
ericsmith32
10 years ago
Chevy Chassis is out of control
Frankly it doesn't seem any different than my grandparents E450 31ft but I'm getting tired of being pulled over! Pulled over outside of Jackson MS because the road suddenly started tossing the RV around and couldn't slow down quick enough (although the step was starting to come down so it was good timing). My wife got pulled over for the same but was the wind in KS. Starting to think it could be our age, grandpa never pulled over except speeding and he's worse than we are!
Planning on this in the following order.. Alignment.. Changing out the rear D Load Range with E's and pumping them up to 80lbs (front are already changed out)... Steering stabilizer up front .. and shocks last.
It does track straight and ride good for the most part but is easily influenced by wind and road conditions. And it does excessively bounce over the dips in the road. Typical RV's that I'm used to but has to be better. Thinking about a rear sway bar to but those are pricey for my budget. Anything I should look into?
