Peg_Leg
Sep 24, 2013Explorer
Check for 2 small wires coming out of the bottom edge of the distributor, just under the cap. These could be cracked and not making good contact. If it won't start try lightly pushing them toward the distributor. If this is the problem it's called the pickup coil. The distributor has to be removed and disassembled to replace it.
38,782 PostsLatest Activity: Aug 23, 2026
