Gjac
Dec 15, 2016Explorer III
bjarnold wrote:What does you ride height measure from side to side? You should have at least 1.75 ins. On a light 28 ft MH your springs may be fine but depending on age and miles driven the springs both front and rear do wear out and the bags alone may not be able to provide the right ride height. As Bud posted many of us had to go with a heavier duty coil spring from Henderson to lift the upper A arm off of the lower bumper stop to get the proper ride height. If it now rides nose up check the ride height in the rear your rear springs may be sagging some.
Right now I have them at 80psi. After the old bags were replaced the front end did come up noticeably. Before it looked like a hod rod with the nose to the ground. Now it is sitting just about level. I put a level inside the freezer and it's actually sitting a little nose high
38,779 PostsLatest Activity: Jun 16, 2026
