bjarnold
Dec 15, 2016Explorer
The shop that did the air bags only works on diesel trucks and farm equipment so they have a pretty good knowledge of what they are doing. They said everything looked fine and they replaced the sway bar bushings as well. They also pulled out the coil springs to replace the air bags which I was not expecting. The ride height on the bumpers is approx. 2". I should have measured the actual "lift" from the new air bags before and after but I can tell you that before I was able to reach above the front side windows to apply wax to the coach now I can only reach half way up the side window's. So probably 6" or so
