1969SSCamaroExplorerApr 12, 20141995 P30 Differential Problems; Large ShavingsAfter draining diff fluid, I found some large shavings on the magnet. I feel compelled to remove the entire differential for closer inspection. So far I can see nothing obvious like a disintegrated b...Show More
Mike_HohnsteinExplorerApr 12, 2014Drive side is supposed to be more centered, suspect pinion bearing failure.
Related ContentDifferential ServiceAtwood water heater problemTroubleshoot fridge problem...Differential fluid changeNorcold Model 611 Fridge problem
