1969SSCamaro's avatar
1969SSCamaro
1995 P30 Differential Problems; Large Shavings
After draining diff fluid, I found some large shavings on the magnet. I feel compelled to remove the entire differential for closer inspection. So far I can see nothing obvious like a disintegrated bearing cage, but it is all but impossible to see the differential gears. I measured backlash at .009 and looked at gear mesh using ring/pinion paint; see photos. Based on gear mesh patterns the coast side looks to be a little too high on the ring gear. I'm certainly no expert reading these patterns, so input welcome. I do have some reference material. The drive side looks okay to me.
Link to Photos of Diff Pattern and Shavings
Second link to photos - slideshow
  • Mike,
    I assume you are referring to the primary pinion attached to the driveline? The primary pinion bearings appear to be fine. I removed the pinion a few days ago and inspected it. Or are you referring to the differential pinions? I plan to remove the differential assy tomorrow and inspect the differential assy. Apologize if I'm asking silly questions, but I am a novice working on differentials.
    Anther strange thing is the ring gear at the root-heel (very outside edge of the ring gear) gives an appearance like the pinion is meshed too tight; the edge of ring gear has slightly splinterd edges. I expected the pinion to be too close to the ring gear; meshing too close/deep, but the mesh patterns in the photos do not indicate that.
  • Also not an expert but considerable experience, the ring and pinion appear OK. The metal pieces look to me like chunks of the axle gear bushings and/or spider gear bushings.
