DrewE
May 26, 2016Explorer III
Also double-check that the cables going to the battery are good and solid where they connect to their terminals. If the ground connection goes to the chassis fairly directly, check that connection as well. I've seen battery cables that appear OK when looked at but are actually barely or not connected at all, with the wire broken or corroded next to the ring terminal.
